My tv color’s are inverted.
my tv color’s are inverted.
Это хороший вопрос?
@ashok26808 first let us know what exact model your TV is. Then you want to check the color settings in the menu. see if there is an invert and try to adjust the colors. If none of the adjustments work, the issue is most likely related to a bad Gamma IC. For any further information we will need to know the exact model for your TV. The Gamma IC can be on the main board, T-Con board or even the LED driver boards.
IF your TV has a T-con board, then this is the most likely culprit. IF it does not, it could be the main board or the LCD driver boards.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За всё время: 74
