How do I disconnect my fuse box under the hood
How do I disconnect my fuse box under the hoid
Это хороший вопрос?
Это хороший вопрос?
@stephensvrcek use the workshop manual to remove the Lamp:
HEADLAMP UNIT
REMOVAL
LAMP
1. Disconnect and isolate the battery negative cable.
2. Remove the grille panel from the grille opening reinforcement.
3. Remove the two screws that secure the mounting tabs (3) on the inboard side of the headlamp unit housing (2) to the grille opening reinforcement (4).
4. Pull the inboard side of the headlamp unit away from the grille opening reinforcement far enough to disengage the locator tab (5) on the outboard side of the unit from the engagement slot in the outboard edge of the reinforcement.
5. Pull the headlamp unit away from the grille opening reinforcement far enough to disconnect the wire harness connectors from the headlamp bulb socket (North America), the headlamp bulb base (Export), the front position lamp socket (if equipped), and the headlamp leveling motor (if equipped).
6. Remove the headlamp from the grille opening reinforcement
Here is the part from the manual Jeep Liberty Lamps
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 43
2 Комментариев
@stephensvrcek just wondering why you would want to do that. Are you planning on removing the complete fuse box?
из oldturkey03
No I need room to replace my headlight
из Stephen Svrcek
