The Nuova Simonelli Oscar II is a high-quality espresso machine suitable for home use or small cafes. It has a professional portafilter and a powerful steam nozzle for milk preparation.
Not enough water running to have an espresso
Greetings,
When I try to make espresso, the water that comes out is very little and inconsistent. In addition to the fact that it has very little pressure. Even without using the filter holder, the water that comes out is minimal. What could be the problem: water pump, a clogged line?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Probably a clogged line.
Start by the descaling routine.
If unsuccessful, you will have to access the brewing head and descale it manually
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jonathan Rivera буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 231
