Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
Phone screen completely blank, phone itself works
I dropped my Pixel 3a a couple weeks ago and broke the screen (physically fine, but showed white static for ages; then displayed properly, but touch wouldn't work).
I attempted a self-repair and completely exploded the old screen because I am dumb, but I got the new screen connected and it worked perfectly - turned on, displayed crisply, touch worked, yay.
But when I came back to it the next day, the screen was completely unreponsive, and still is. The phone seems to work normally - chimes when I plug it in for charging, makes notification noises, is detected when I plug it into my PC - but the screen just doesn't work, even though it worked fine when I attached it, and I didn't move the phone at all between the time it worked and the time it stopped.
I've tried shining a bright light on the screen to see if it's a backlight issue, but I can't see anything displaying even then. I've also detached and re-attached the screen, and restarted the phone multiple times; again, no dice.
I can only presume I've broken the replacement screen somehow, though I'm sure I was super-delicate in handling it. Does anyone know anything else I could try, short of buying a second replacement screen and trying again? Cheers for any help.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
You need to replace your phone’s screen again.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
MonarchDodora буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 29
За всё время: 459
