Can I convert my 4.2 volt hand drill to use 5v or 12v DIRECTLY?
I have a 4.2 volt drill and the battery life is really annoying so can i replace battery with a 5 volt soldered input to directly power the drill, or could i use 12 volt to directly power the drill. Which one is more safe? Id like to challenge myself with this project. Are there any limitations. I just want it to work. i.e. : my device does not exist on ifixit site so ill attach an image.
Это хороший вопрос?
1 Комментарий
The risk of using a 12v battery on a 4.2v small electric screwdriver may result in premature burnout of the motor from over voltage and current. Not advisable as this can shorten its life. Using a 5v source from a battery is safer and allows longer life as an external power source. Three 1.5 volt batteries adds up to 4.5 volts. A little higher if using rechargeable batteries. The physical size of batteries determines how long the power lasts.
из F Dryer
