Green line down the center of screen
I replaced the battery, and now I have a green line down the center of the screen. Right down the middle. I'm hoping it's just the connector not seated correctly. Has anyone else seen this before?
Это хороший вопрос?
4 Комментариев
Did you use the isopropyl alcohol to clean the adhesive off the display and battery?
из Jacob Mehnert
I didn't need to on the screen side. It all came off surprisingly easily. I did use it on the battery side and needed to put some under the battery as the pull tabs broke off.
из mary
@mdrumhel but you did use some? Some users have reported this happening with Rubbing Alcohol.
из Jacob Mehnert
I did use some. That's interesting. Has anyone reported fixing it without needing to completely replace the screen?
из mary
