Engine overheats but no sign of leaks
No leaks but no sign of over heat and the water inside the radiator bubbles white
Это хороший вопрос?
Это хороший вопрос?
I would hazard a guess here based on the limited information you are giving. Sounds like a head gasket failure into the water jacket that is allowing compression loss into the cooling system.... bubbles. If bubbling increases with RPM... that is a dead give away. Sounds expensive if you aren't prepared to DIY. Oh and don't use a lighter to peer into the radiator the lighter than water fuel will rise to the top tank.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 36
