Battery not charging at any base
Ok...so..
The battery isn't charging when at the homebase.
So...I took it to a base that I know works as I have 3 roombas with each their own charging station.
Still not charging but the roomba that goes to this base does charge.
Cleaned off the contacts - failed
Reset the roomba - done but still won't charge.
Took the battery out of the failed roomba and installed it in another one of my other roombas - battery charges. I put the battery back in the original roomba - fails - no charging.
For the hell of it I ordered another battery - failed - still won't charge.
Placed new battery in other roomba - works- battery charges.
I know it's making contact with the base because when the defective roomba moves to the charger it stops BUT the light stays green ( doesn't flash orange to indicate charging is active) The battery indicator slow flashes but then it disappears along with the green lit power button telling me no charging is happening.
I checked the contact pins and they are secure. No movement.
So...What say you guys?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
I am having this same issue.
I check the connection between the battery terminal and the connection pad. The left one works, right one failed.
I took it apart and checked the pins on the circuit board, they all seemed to be fine and making good connection. I want to assume that it's the wire between the circuit board and battery terminal, but not completely certain. Can't find a schematic to help me tease the wires apart.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Yeah...I agree.
It's weird how this just started to happen in just the last week or so.
If it comes to then I'll just pull this puppy apart without a schematic and see what I find. I mean it's kinda useless if the battery don't charge unless I keep taking it out and charge it by swapping it out with one that is charged.
Hopefully there's a more simple solution but I doubt it.
Thanks for your reply.
из
Добавьте свой ответ
Richard буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 495
