The phone comes with a 6.50-inch touchscreen display offering a resolution of 720x1600 pixels at a pixel density of 269 pixels per inch (ppi) and an aspect ratio of 20:9. Oppo A53 2020 is powered by a 1.8GHz octa-core Qualcomm Snapdragon 460 processor. It comes with 4GB of RAM.
My charging port is not working
my oppo a53s charging port has an issue the charger cannot fully get inside
Это хороший вопрос?
Счет 20
13 Комментариев
USB port dry and clean and reset phone ka masge a raha ha bar bar
из
Charging not working
из
@prajju same steps as in my original answer.
из
Charging problam
из
@oppoa5325446 same fix as the original answer unless you have other issues that you have not described.
из
Показать ещё 8 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
@vitin40128 check the port for any debris or bend contacts. If cleaning it or if the contacts are broken, you will need to replace it. Luckily the charging port is soldered to a charging board. It will be much easier to just change the complete board. You are looking for something like this
iFixit doesn't yet have a guide for this. Use something like this video to get this repair done.
While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Был ли этот ответ полезен?
Счет 2
5 Комментариев:
Charge is slow. Charge is slow. Charging is delayed
из
Change charging point
из
из
@ladabeshra you did not provide enough information to actually help you. I would suggest the same thing as in my original answer.
из
Máy bị vào nước sạc thì nhận đc 1s là ko vào nữa
из
Счет 1
Добавьте свой ответ
vitin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 39
За последние 30 дней: 138
За всё время: 3,881
