Oppo A37 A37fw 16GB comes with 2GB of RAM. The Oppo A37 runs Android 5.1 and is powered by a 2630 mAh non-removable (as told by Oppo ;-) battery. First released in April,2017.
How to remove black spots on display screen on mobile
Это хороший вопрос?
Счет 2
3 Комментариев
تغير شاشة نفس المشكلة في جوالي
из
tech display problem
из
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@abdullahiqbal "black spots on display screen" is most certainly a bad display. Replacing it would be the only fix.
Since iFixit does not yet have a guide for that, use use videos like this one as your guide.
Replacement screen are readily available. Just do an online search and find a vendor to your liking. Prices are not to high neither.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Abdullah Iqbal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 356
