My battery dies too fast
how do i fix fast draining battery
Это хороший вопрос?
Only charge the phone with orignal charger and never let the battery percentage below 20% and never put phone on charging if Battery has more then 80%.
Был ли этот ответ полезен?
Reduce apps running at background and reduce light on screen by activating power booster or battery saver.
First, see which apps daring your battery fast or are draining fast in normal use. Try to charge your phone with original charge and see is your battery is normal or getting bigger etc.
If your battery drain quickly you can try to close some app,use a good charger and make sure you don't overheat your phone
You don't charge fast and your way that week
My phone name is tecno spark 20 and my phone battery dies fast night
@danamoako make sure that all of your settings are geared toward power savings mode. Turn off any Apps that are running in the background. If none of that makes a difference, replace the battery and re-evaluate. Since iFixit does not yet have a guide for this, use a video like this to help you out. Batteries are readily available at many online stores. Check a vendor in your geographic region since shipping of batteries can be tricky.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
За последние 24 час(ов): 1
За последние 7 дней: 13
За последние 30 дней: 69
За всё время: 3,557
7 Комментариев
charge the battery
из Keith Mazyopa
My phone goes off at 36%
из Mamoud Fofana
@mamoudfofana start by replacing he battery then re-evaluate.
из oldturkey03
TECNO LC7 battery die too fast,
What is the means of repair please
из Usmansado
Sparc 30 burning batry
из Alemayehu minichil
Показать 2 больше комментариев
