The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
418вопросов Показать все
Missing components C5C 11,12,20,21,22
Missing components: C5C11, C5C12, C5C20, C5C21, C5C22. I only need the components mentioned above and I am unsure about where to get them
Это хороший вопрос?
Оценка 1
2 Комментариев
@phillip96884 Can you upload pictures of your motherboard that show the spots where the missing components should be?
из
I will upload some
из
Добавить комментарий
1 ответ
Выбранное решение
@phillip96884 these capacitors are all the same. They are 0.01µF 16V 10% in a 0402 package. I prefer Mouser.com or Digikey. com but ultimately you can purchase these where you would like to. I do not get any kickbacks for mentioning those companies. It is just my preference. Check on here for the caps. You can always use the mfg. part number and do an online search to find different vendors.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Thank you for the help
из
@phillip96884 anytime and best of luck with your repair.
из
Добавьте свой ответ
Phillip будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 23
