Ps button on ps4 controller is automatically long pressing
My Ps4 controller is acting weird
To keep it as short as possible, so i was playing GOW one day and suddenly my ps4 controller got turned off (it had full battery), and when i tried to switch it on it wont. When i plug it in the charger it is charging normally so it did not die on me, and i could narrow down the problem but there was no solution on the internet for it so here i am. ( i have opened it up and cleaned it properly)
Basically what happens is the controller is thinking that is PS button is long pressed the whole time. When i single press the button it registers as a long press and when i keep it idle then it switches off like when you hold the ps button for 5-7 seconds then it wont turn back on so i have to open it up again and reassemble ( and no the casing is not tight ive tried when the case is loose and super tight) When i open it up and reassemble it, it works fine for a few minutes and then the problem starts again.
The button works just fine without the plastic case when i press the rubber pad on the circuit ribbon button but the problem starts after a few minutes when i reassemble it. The pad is sitting in the correct position as well so no problem there. Any anyone help me with this or has anyone faced this situation before?
Это хороший вопрос?
