Why is my nintendo switch overheating
I've been playing on my nintendo switchI've been playing on my Nintendo switch. And it lasts like, twenty minutes before it shuts down
Это хороший вопрос?
Это хороший вопрос?
How much have you been using your Nintendo switch? If you don't use it a lot.. I'm not 100% sure.. if you do use it a lot.. then limit your usage, because it might overheat.. I hope this helps at least a bit..
Был ли этот ответ полезен?
@sparker9789 "And it lasts like, twenty minutes before it shuts down"
It sounds likely that the cooling fan is no longer functional. If that's the case, consider this guide (also available below) as reference for the installation of a replacement. There's the possibility of another component causing the loss of the fan's functionality, but that would require more thorough evaluation.
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 113
