Why is my laptop shut down suddenly?
my laptop shut down suddenly and randomly sometimes when started other times on the middle of doing some things
Это хороший вопрос?
Это хороший вопрос?
Possible solutions
To launch the Windows Memory Diagnostic tool, open the Start menu, type "Windows Memory Diagnostic", and press Enter. You can also press Windows Key+R, type "mdsched.exe" into the Run dialog that appears, and press Enter.
If the problem doesn't happen while in the BIOS settings screen (usually pressing the F2 key after pressing the power button) I would suspect a corrupted driver. First of all see if any drivers are corrupted by checking in the Device Manger. I would start with the Bluetooth. Just uninstall but don't delete the drivers and let Windows reinstall by clicking on Action > Scan for Hardware changes up in the menu.
If that doesn't work hopefully it is just an easily removeable hardware component with an intermittant failure. Try removing one at a time and testing each time. I would start with the RAM. For the RAM remove modules (usually there are two) one at a time and also try in each individual ones in each slot. Then Bluetooth, Wi-Fi, etc. Even an intermittantly defective hard drive could cause the problem.
The IFIXIT Repairs Guides will help with disassembling. Click on the blue text below.
Acer Aspire 4520-5464 Repair Guides
Let us know how it goes.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 35
