vivo v5 Phone does not charged
Это хороший вопрос?
Well I will suggest to check your charging port for any physical damage and also the charging cable as well.
Был ли этот ответ полезен?
@mukulbairagi there are a few things that can be doing this. Check your charger and charging cable. Next check the charging port. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If all of that looks good, you want to replace the battery. If a new battery does not work, then you need to replace the charging board. Some people prefer to repair the actual charging board but that requires a replacement port as well as soldering. I would suggest you replace the board. Follow this video right up to 1:40
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 31
