The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Why is my phone ink always spread on my screen?
My phone has a small ink on the screen but every day out it starts spreading. What should I do to stop the ink from spreading?
Это хороший вопрос?
Счет 8
4 Комментариев
My phone in Infinix note 10 pro max my problem is pone has automatically black line in this screen
из
@infinixnote5092
See the Most Helpful Answer below for what to do.
из
из
@jane21237, out of curiosity, what is your point in copying the exact question and posting it as an answer? You could simply say you have the same problem; that way you won't look so much like a troll or a spammer.
Anyway, if you are seriously asking, the question has already been answered authoritatively; see the Most Helpful Answer if you really want to know.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
@benjaminanaman your phone has an AMOLED. Display. When these crack they leak. The only way to repair this is by replacing the screen.
Since iFixit does not yet have a guide for this, use something like this video to replace the display. Replacement displays are available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Был ли этот ответ полезен?
Счет 4
Well it usually means your phone's display panel is damaged, likely from a drop or impact on your phone screen which causing the liquid crystals inside to leak and spread. So I will suggest you to fix your phone display it can cause more damage to you phone display.
Счет 1
Your phone screen likely has internal damage, causing the "ink" (LCD liquid or pixels) to spread. This happens due to pressure, heat, or further cracks. To prevent more damage, avoid pressing on the screen, use a screen protector, and get it repaired or replaced as soon as possible.
Счет 0
Charge problem
Счет 0
1 Комментарий:
Hi Ally,
Please start your own question, especially since your question has nothing in common with the original except (perhaps) the type of phone it's happening to.
This way you are much more likely to get an answer. We will, however, need more detail, since there are many possible reasons for charging problems. What has happened to the phone recently; any damage or liquid exposure? Have you check the charger and cord, either by trying a different one or making sure it works with a different device? What else have you done to try and troubleshoot the problem?
из
Добавьте свой ответ
Benjamin Anaman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 103
За всё время: 2,524
