Charging problem - replace Micro-USB connector?
I can't charge the headphones. Is it possible to replace the Micro-USB connection?
Это хороший вопрос?
Это хороший вопрос?
Why do you think it is the connector? There are a number of other possibilities including the charger and the battery.
Post any symptoms you have experienced in the past.
Был ли этот ответ полезен?
I have several chargers.
The problem occurred suddenly without deteriorating battery before.
I can visually see the damaged connector.
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 32
За все время: 621
I also have this issue.
With the charger disconnected I see a blue led light of the pairing that is always on.
When I connected the charger to the micro USB connector a red led light starts flashing and the blue led light continues to be on.
I already replaced the battery. I was now thinking on replacing the micro USB connector. Do you have any other idea's?
из Helder Marques Поделиться
If you have 2 LEDs, the blue one is telling you it is on and paired. The blinking red one is telling you it is charging. If there was a problem with the connector, the red LED would not be flashing when you plug it in. However, if it is "flashing' (fast blinking) it may be telling you there is a problem with the battery or something internal.
из bill Поделиться
