Battery was replaced but doesn’t show charging
After I replaced the battery and got everything connected, I plugged it in and it worked but after 20 minutes of not being plugged, it’s suddenly not charging anyone.
The battery is from Ifixit, I followed the guide/video to a T.
Has this happened to anyone?
Это хороший вопрос?
Оценка
0
Per iFixit: Without calibration, the battery percentage reading will be incorrect, and your device may behave oddly—shutting down suddenly even though the new battery “reads” half charged, or working for hours when the battery reads nearly dead.
I would read up on this to calibrate your battery and see if this resolves the issue: Battery Calibration
из Kuromi
There's no chime so the device doesn't charge at it so I can't calibrate it.
When I turn the phone off and plug in the charger it turns on but other than that the battery isnt charging. I left it charging for 2-3 hours and the % went down by 2
из Christian Wu
@christianw13120 I saw on your post that the device is an iPhone 11, did you get a battery from iFixit or a 3rd party?
из Kuromi
@kuromifanboi I got it from IFixit
из Christian Wu
@christianw13120 the iPhone 11 battery has a 1 year warranty according to iFixit (The iFixit Guarantee)
I would contact iFixit as they will be able to warranty the battery as there could be a defect (https://help.ifixit.com/category/133-con...)
из Kuromi
