Why my phone is charging too slow?
My phone takes 12 hours to charge 0 to 100...I think it is charging ic issue ..if anyone has a solution please tell me....I used Tecno original charger also but all in vain
Это хороший вопрос?
Это хороший вопрос?
@hamzamujahid could be but it can also be a few other thing. I would start off by replacing the battery. If that does not improve things, Replace the charging board. Since iFixit does not yet have a guide for this, use something like this video Replacement parts are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
U have to change the subboard
Yes, sub-board is the best solution, but check other cord first
change charging ic
or use zenor diode
@djdemo where is the charging ic? What type of ZenerDiode? Where is it? An answer means that the person that is asking, can use it to fix their device. Your answer is very incomplete.
Use jumper wire
@azalinzambe jumper wire on what? From where to where? An answer means that the person that is asking can use it to fix their device. Your answer is very incomplete.
Might be possible that phone's apps running in the background consume power even when you're not actively using them, slowing down charging.
Please a am phone repairs Please i want to learn more about to get 🙏
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 66
За всё время: 2,964
9 Комментариев
I don't know
из Adnan
I have the same problem
из Godson Nyimfah
My phone charge slow
из Godson Nyimfah
Not charging fast
из Asante Salient
@asantesalient have you read and followed the answer provided?
из oldturkey03
Показать ещё 4 комментариев
