Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
Factory Reset without TV Display or Wifi
I bought a fire stick 4k but I believe it's trying to do 4k on my 1080 and it isn't showing anything, just a black screen. This is even before the initial setup. Is there any way to do a full factory reset without being able to see anything on the screen? And before any wifi because again, this is before even the first setup.
I believe somehow the display settings got messed up and won't give me a display on my tv. Doing a factory reset should(?) reset it? Maybe adb? Or blindly holding buttons on the remote?
Thanks,
Josh
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@spiffynigma If the remote is connected to the stick, you can perform the following procedure:
  1. Press the back button and the right side of the navigation circle for 10 seconds
  2. Wait several more seconds for the device to start the reset procedure
The device should reboot and eventually cone up with the initial setup screen.
Let me know if it worked, or if you have any questions.
https://www.amazon.com/gp/help/customer/...
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Spiffy Nigma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 41
За всё время: 1,703
