Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3666вопросов Показать все
Reading Solid-State Drive externally
I have been tasked to pull the data off a MBA.
The computer is trashed and no longer available.
It appears the SSD is in good shape physically.
Are there any readers, cables or external devices that can extract the data off this SSD?
Joe
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
You can mount the SSD in an external case. If it's not damaged it should be easy to recover data from there... There are data recovery tools or services . . . your milage may very... good ones are not cheap.
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
The question is what device is available out there to read this SSD?
Where does a person get a converter cable or reading device.
I realize that once it is cable up I could use numerous to read the device (ie: USB, Firewire....)
из
Well they sell them here - otherwise Google Shopping is helpful.
из
External HD kits include all required cables.
из
Добавьте свой ответ
j4piper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 478
