Is it possible to change the processor from 2,0 ghz to 2,4 ghz?
Is it possible to change the processor from 2,0 ghz at 2,4 ghz?
Это хороший вопрос?
Это хороший вопрос?
Apple went back and forth between an integrated CPU and a removable CPU. Unfortunately, I believe this model features the CPU integrated onto the logic board.
You can, however replace the logic board with a 2.4 GHz board from a Mid 2007 machine (do a Google search for part number 661-4439). But that won't be cheap. Your call!
Good luck!
Был ли этот ответ полезен?
hi!
ups....2200 us dollar??? for this part number 661-4439 board???
my iMac has costs 1029 euros COMPLETE!
thank u for answer, i buy a new iMac it is cheaper.
rene
That's probably a wise move. It's amazing how expensive specific parts can be!
I've had two 2133 20' iMac's and both had a removable CPU. I replaced the 2,0 Ghz processor of one of them by a 2,4Ghz (coming from a 24" defective logic board) and it runs perfectly well. It shows up in the system info part as a 2,4 Ghz Intel Core 2 Duo.
So have a look under the bonnet to see if it's removable !
Likewise can I also replace a 20" iMac(2133) 2.4 Ghz (mid-2007)logic board with an iMac (2210) 2.6 Ghz(early 2008) logic board? Are the components compatible i.e. WiFi,Bluetooth etc? The step by step guide seems to imply that you can as the instructions to remove/install are exactly the same.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 2,925
