The head is loose on my 620 pro mosdel
How do I tighten the head on my 620 pro model
Это хороший вопрос?
Это хороший вопрос?
There are three screws inside the mixer located underneath the motor which attach the mixer body to the base. You may be able to access them by just removing the cover. It can be a bit difficult to get sufficient torque to do this. If you can't put enough torque on them to tighten them down with just the cover removed, then you will need to remove the motor. This guide will instruct you on how to remove the motor to access these screws: KitchenAid Professional 600 Drive Motor Replacement
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 60
