screen isn't turning on after replacement
wont turn on after screen replacement
Это хороший вопрос?
Это хороший вопрос?
Is the original screen still in a sort of working condition so that you reinstall it to check if the problem is due to the replacement display or on the systemboard?
If not, it may come down to board level testing using the service manual to find out what's wrong.
I couldn't find a free download online, you may have better luck.
Был ли этот ответ полезен?
Hi @michelle51666,
See Step.51 of the ifixit Samsung Galaxy S22 Screen and Battery Assembly Replacement guide
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 62
Hi @michelle51666,
Have you checked if the display flex cable is securely connected?
из jayeff
sm 901 and I had it all apart and put it back together everything seems in place an tight
из michelle
i think so im no pro at all tbh i have no idea what im doing i watched alot of youtube so idk if i even know which flex cable that is
из michelle
