The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
Flipper Zero. Stripped the screws a bit. What do I do?
I used a small metal screwdriver when trying to replace the housing shell and I think that it was stripped a little, but not as much. I don’t want to continue to try to unscrew it with the risk of completely stripping it. Any ideas?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
If you are un-screwing, usually the problem is using too big or too small of a screwdriver. Get the size that is big as possible that fits and press in as hard as possible when unscrewing. I don't yet have a flipper, so I can't recommend a screwdriver. ( but plan to buy one soon, such an amazing device)
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
The proper size is PH0
из
First get the screw out and take them into a hardware store or electronics parts place and have them get you placements and then reinstall using the proper sized screwdriver
Счет 0
Try soldering iron and twist with your screw driver
Счет 0
Добавьте свой ответ
KingCool буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 59
За всё время: 625
