Can the lens be replaced?
Is the lens screw on m12 and can it be removed and replaced as you could with older models?
Это хороший вопрос?
Это хороший вопрос?
On the GoPro 10, 11, and 12 models, the lens can easily come off as you rotate the cover, and then the screws are visable.
Hope you find this helpful!
Был ли этот ответ полезен?
Does this mean that you can just unscrew the lens from the assembly?
The m12, and the flange being the only issue left?
Yes. You will be able to unscrew the four screws after rotating the lens cap off.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 76
