Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
What SSD will work in my late 2012 iMac PCIe 7/17 socket
Hi
I have a late 2012 27” iMac
Serial no C02KD9RSDNCV EMC no 2546 model A1419.
I want to add a SSD into the empty PCIe 7/17 socket, I have searched the net for a blade type SSD that will work, I have found 1 or 2 that are supposed to work with mid 2012 to early 2013 variant, iMac like
1.0TB OWC Aura 6G
Solid-state Drive for iMac (Late 2012 – Early 2013)
Mfr P/N: SSDIM12D960
OWC SKU: OWCSSDIM12D960
or
Mid2012 - Early2013
MacBook Pro A1398 A1425 SSD
口128GB
• 256GB
512GB
1T8
P/N: MZATEA 1398 HMHP
S/N: 20208112021398
MODEL: MZ-A1398A1425
but the model number given is A1418, can anyone tell me if my model A1419 is compatible?
If my iMac will not support these drives is it possible to use an adapter to change the 7/17 socket to one that will accept a more readily available SSD?
If anyone had upgraded there iMac either with a module that will go into the existing socket or used an adapter that allowed the use of a more readily available SSD, could they post the part numbers or name of the hardware they used.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Here’s a useful write-up on the Apple drive specs and what the system can use The Ultimate Guide to Apple’s Proprietary SSDs as noted the interface is a mSATA III (6.0 Gbps)
The OWC Aura is what I would use.
Был ли этот ответ полезен?
Счет 0
@lesmilton The SSD that you're looking for is here (take a look at the available options). If you're looking for other options, it might be easier to use the EMC 2546 number or the iMac13,2 identifier.
Счет 0
Добавьте свой ответ
Les Milton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 220
