ماهو حل الشحن البطيء
Google translate:
What is the solution for slow charging?
Это хороший вопрос?
Google translate:
Это хороший вопрос?
بسبب إستعماله أكثر من اللزم
Translation
Because it is used too much
Был ли этот ответ полезен?
@khalilgannoun the very first thing you want to do is to change your battery. Since iFixit does not yet a guide for this so go ahead and use something likethis video to work on your phone.
You also need to close check the flex cable coming from the charging board. Once you have your phone open, I would even go as far as replacing the charging board and the flex since both can be a source of failure as well
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 26
