Repair guides and information for portable, battery-powered Bluetooth speakers
oontz curve Battery Replacement
Looking for a guide and parts to replace the battery on a Oontz curve. I don't know how to get it open.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I just figured this out. Underneath the unit is a circular rubber pad. It's attached with a sticky adhesive, but can be easily peeled off. Once removed, you'll see four small Phillips screws that hold the plastic base to the top metal part. When the four screws are removed, the top and bottom parts will separate. You'll see the battery in the base. Good luck!
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thanks for information ooga chaka. It was very helpful finding the battery however, the battery was stuck to part of the circuit board because of all the glue the manufacturer had placed onto the foam pad to seat the battery in place. The other issue is that the battery leads are soldered to the small circuit board so replacing the battery requires an expert soldering technician. A second issue is finding the replacement battery because everything has been manufactured in China so Good Luck with that!!!! Rewrote to correct some spelling mistakes.
из
Добавьте свой ответ
Michael буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 67
