Repair guides and disassembly information for the 16-inch MacBook Pro released in January of 2023, featuring Apple-designed M2 Pro and M2 Max SoCs.
Can I replace the keyboard on my 2023 16" MacBook Pro?
Hi Folks -
I spilled soda on my MacBook keyboard several months ago and the keys are still sticky. They get worse when I run high compute functions such as rendering or Final Cut Pro, probably due to heat. Apple wants $1,500 to fix it because they require a full liquid-damage assessment to ensure it didn't damage other internal components. I'm willing to pay but not that much.
I'm not seeing a keyboard for this model on iFixit, anybody know if the keyboard in this model can be replaced or where I can find the parts?
Thanks,
John
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
O’boy you do have a sizable problem!
Apple is the only source for parts on these newest of systems as there are just none out there being sold as parts. Reference the Apple Self service site Apple Self Service Repair depending on where you are your options might be limited. In any case reference the repair manual 2023 16” MacBook Pro do take note the keyboard is part of a sizable uppercase subassembly. Apple doesn’t offer the raw keyboard as being so new a system I don’t think anyone has discovered a replacement, besides the different countries have different keyboards or KeyCaps which adds a bit more to the mess.
The last issue here is like the older 2012~2015 Retina models one needs to be quite physical getting the old keyboard out as you need to takeout a good number of plastic rivets (~80) and some screws as well. I’ve long since given up trying to do the keyboard alone as in the end the repair is not as good.
Bottom line just bite the bullet getting the full assembly! After a liquid spill things can crop up later.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
John Gearty буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 120
За всё время: 2,141
