kenwood kdwx60x20 unlisted fault code
I have kenwood kdwx60x20 and the fault code is rinse aid salt and 1/2 load light flashing , beeping , won’t finish cycle fault code is not listed in the booklet , been going on for 1 month unit is less than year old
Это хороший вопрос?
Оценка
0
Hi @lukefyfe1991
Remove both the baskets and the lower spray arm (upper spray arm should come out with basket) and the filters and then try running a cycle for about 20-25 minutes.
If it works, there may be a blockage in the spray arm outlet holes
See p.32→ p.33 of the user manual for how to remove the filters and the spray arms
из jayeff
I have tried this and still faulting . I’ve also removed the drain pump to check for debris and no signs there . I’ve also checked that the anti flood switch isn’t triggered , cleaned all filters also . Confusing as the fault code is not listed in the book
из Lukefyfe1991
@lukefyfe1991
If it is <1 year old, contact Kenwood customer service and ask for a warranty repair on the dishwasher.
There's a 1 year warranty on most Kenwood products.
из jayeff
