Will the joysticks from the original steam deck work with the OLED?
Will the joysticks from the original steam deck work with the OLED? If not where can I get them. Dog chewed up my left joystick 2 days after getting it....
Это хороший вопрос?
Это хороший вопрос?
Most likely yes. 95% of controllers nowadays use the same type of thumb stick. The steam deck should be no different. You,ll be even better with replacing it with thumb sticks from another Steamdeck. The only difference between the LED and OLED models are the price, the screen, and the power consumption. Hope this helps. Have a good day.
Был ли этот ответ полезен?
I was looking for the Joystick and the board as a unit. I'm sure I could solder it to the exisiting board no problem. The joystick w/ board is redesigned from the LED version.
Ohhh. Ok. I cant help you there. But best of luck
За последние 24часов: 4
За последние 7 дней: 9
За последние 30 дней: 62
За всё время: 309
