Samsung TV The screen flickers
Samsung UE58TU7100K
Did you guys end up figuring this out in the end? Seem to have the exact same issue. Thanks
Update (01/04/24)
Hey, have checked the voltages, all seem okay, also the flickering stops with just the right hand side buffer board disconnected. Not sure if this helps with the diagnosis though
Update (01/04/24)
I cannot see any physical damage.
Это хороший вопрос?
@lucasblackhurst "the flickering stops with just the right hand side buffer board" any damaged components on the driver boards that you can see? Check the connector for anything charred etc? Post some images. You'll have to post it as an answer since iFixit does not allow pictures in comments.
из oldturkey03
