iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Why does my internet connection repeatably drop out?
I have tried a few fixes for this issue that I found on google but the issue still seems to be troubling me.
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi @jakeperry,
Does the problem occur when using either WiFi or Ethernet for the internet connection?
из
To add to Jay’s question what is your means of connecting to the internet? Cable/Fiber, G5 wireless Modem or StarLink?
из
Добавить комментарий
1 ответ
There is a lot to be desired in the question. It equates to, "why doesn't my car run".
Does it only drop out on the MAC?
If not, the question is not about the MAC.
Do you have WiFi?
If so, is it dropping out on both WiFi and Ethernet?
If just WiFi, do you have a separate gateway and router?
If so, the problem is in the router. If not, the problem is in your Gateway.
Is it your router or your ISP's router?
If yours, then YOU may need to replace it. If not, call your ISP.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jake Perry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 119
