I've seen an official document from Apple that specifically states there is a software lock on what they refer to as "Phone Rear or Mid System" for your phone. So I would say yes, you will run into issues, but I'm not clear exactly what those will be. Generally most locks generate warnings on your phone and/or limit minor functionality, but I'm fairly sure it won't do anything major like disable your ability to charge wirelessly.
@flannelist Alisha, do you have any further information on what to expect for a rear panel replacement?
You can also check out the iFixit teardown that specifically comments on software locks that were found.
iPhone 15 Teardown Reveals Software Lockdown
They specifically mention that changing the wireless charging coil will result in function loss, as in "Parts Pairing or Calibration Issue," as they put it.
So yeah, if you're really dead set on replacing that rear panel, you should probably assume you'll need to swap over the charging coil in order for everything to work 100% correctly. Of course, you could try it out first and see what happens; if there are issues you should be able to just put the original panel back on to clear them up.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
