Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
plastic panel on bottom of screen is cracked
the black plastic covering on the bottom of my screen - the part with "MacBook Pro" on it - is cracked. where do I buy a replacement one? it does not appear to be connected to any components and is just secured with adhesive, can anyone also let me know if this is an incorrect assumption.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Well to start off the chin plate is glass! So to be careful you don’t cut your self.
Using a hair dryer or heat gun at a low setting and shielding the screen you should be to carefully unstick the plate using a thin spatula. Don’t dig too deep as there are fragile cables just behind which you don’t want to damage.
Here’s the needed part Chin Cover Plate MacBook Pro 16"
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Teddy Albano буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 258
