Same issue, but with a MacBook Pro Early 2011.
Here's what I did to fix this: I first attempted to boot in Internet Recovery (Option + Command + R at startup). That didn't even work for me. So, using a separate Mac, I made a bootable USB Drive. Créer une clé USB bootable The Mac was able to at least boot at that point.
After I formatted the SSD, I reinstalled macOS using APFS. And yes, by the time macOS installed and I got back into the desktop, IT WAS SLOW!!!!! Like, way slower than with the Hard Disk (HDD) Drive.
After spending many, many hours on the internet looking for a solution, here's what I found: You need to activate TRIM Support. After loading into the Desktop, open Terminal, and type sudo TrimForce Enable
. You will need to type Y several times, and then eventually the Mac will Reboot. After that, the Mac should be running just fine.
To make sure TRIM support is enabled, go to the Apple Menu > (While Holding Option) System Information... > SATA > TRIM Support. If it says "Yes," you're good to go. If it says "No," punch in the command one more time.
Hope this helps, best of luck!
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
