Whirlpool top loader will not spin all water ar final rinse
I have replaced cogs, coupling and pump checked both hoses for small items it will not drain all the water at final rinse about 2 inches remain what else should I do
Это хороший вопрос?
Оценка
0
What's your exact model number?
из Matt Zieminski
It is WTW5300SQ0 I have replaced cogs pump agitator and checked hoses thank you for you help
из Amanda Pittman
@amandapittman
Have you checked that the drainpipe that the washer drain hose is inserted into is not clogged slowing the draining?
If possible try a small load and leave the drain hose out of the drain and place it in a suitably sized tub, bucket etc and check if it fully drains.
из jayeff
