Lens cover won’t stay in place
My Eufy video doorbell is c 3 yrs old.
I recently noticed there was water under the glass disc which covers the camera lens and brought the device indoors to try and dry it out.
The lens cover subsequently fell off and will not stay back in place.
On inspection, it seems the “bezel” which retains this glass disc, and keeps things waterproof, has degraded.
The company can’t give me any advice re repair and just tell me to buy a new unit.
I feel this is wasteful - and surely the design life of this sort of tech should be longer than 3 years!
Can anyone suggest a safe way I could secure the glass cover back in position?
The only thing I’ve though of is tracing a bit of glue round the perimeter with a cocktail stick and then pushing the lens cover back in position.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I had exactly the same problem and added some kit (TEC7) between the protective plastic circle (it is not really a lens) and the enclosure. Make sure the lens is dry and don't push to hard when closing it. I used 2K glue before that, but that didn't keep it watertight. The TEC7 kit (some kind of silicone kit) worked better.
But then the microphone died after a while and I can't get that repaired...
Был ли этот ответ полезен?
Счет 1
Mon disque s'est détaché, j'ai mis de la glu en gel, mais il y a un nuage sur la lentille comme si la glu avait déposé un film ???
Je vais essayer de démonter par l'arrière et regarder si je sais essuyer avec un coton-tige.
Si je dois remplacer le matériel, j'achèterai certainement une sonnette Tapo de TP Link, j'ai plusieurs camera c310 et c320 qui sont à la pluie battante depuis 2 ans sans soucis. Ma lentille s'est juste détachée 1 mois après la fin de la garantie.
Счет 0
Добавьте свой ответ
Betty Mack буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 14
За последние 30 дней: 66
За всё время: 1,145
