Xiaomi Mi 11 Lite 5G NE — это смартфон среднего ценового сегмента от компании Xiaomi, выпущенный в сентябре 2021 года. Устройство оснащено 6,55-дюймовым AMOLED-экраном, основной камерой на 64 Мп, сканером отпечатков пальцев, расположенным сбоку, аккумулятором емкостью 4250 мАч и процессором Snapdragon 778G.
Screen turned black but device works (including touch screen)
I've had this problem for a couple months now. Basically the screen turned black but the entire phone including the touch screen keeps working.
Usually it just needed some squeezing, light hitting it with my hand or forced reboot to return working, but I have not had any luck this time.
I have swapped the original screen with a new one, but it didn't solve the problem. When I opened the back cover, some screws fell out and the others were quite a bit looser.
I can currently access the phone via usb debugging (mirroring the screen) using a script called scrcpy.
I have tried anything I could (cleaning the LCD pads, swapping back and forth the original one, disconnecting the battery, etc.).
What could possibly be the cause?
Just in case I have the USB daughter board on order to hopefully solve some other problems (phone disconnecting from windows when accessing big files, android auto not working).
Это хороший вопрос?
Счет 7
Добавить комментарий
1 ответ
mi display no light
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Isso aconteceu quando tirei o brilho automático e o brilho ficou no mínimo, fui para um lugar mais escuro e fazendo tentativas de aumentar o brilho até que acertei o botão do brilho e a tela voltou a funcionar com o brilho normalmente.
из
Добавьте свой ответ
Francesco Simonetta буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 41
За всё время: 1,161
