The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
How do you remove lower steering column cover
The ignition key is stuck in the ignition. I've tried the key release with no luck. I need to remove lower steering column cover to see what's going on. How do you remove the lower cover?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
There is a key removal bypass underneath the keyhole to remove the key when this happens. I pulled up a video for you that shows you how to use it to remove the key.
https://www.youtube.com/watch?v=UNVbCakt...
Hope this helps!!
Cheers
Monte
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Dane Justice буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 301
