The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Disk drive making horrible grinding noise
My 360 s is making a horrible grinding noise and almost sounds like the disk is just being thrown around inside the tray. It'll start to read but then just go crazy. Anything I can do to fix?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Figured out the issue shortly after posting. So I'm leaving this up in case someone else has this problem. I was at a point I thought I'd need to replace the drive. But I took the top cover of the drive off and decided to try and remove the magnetic top spindle. Peeled back the labels and pressed out the circular lid out the top of the cover. Once I did that I noticed the 3 piece top spindle was separated causing the magnet to be off balance. It was very simple to realign the tabs with the magnet back in the center. After that I closed it all up and tried it out. Drive sounds like brand new.
I spent hours trying to find how to videos with this same problem without luck. So I'm hoping by leaving this up. Someone else will be helped by it.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Rob G будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 371
