Repair and disassembly information for Samsung's S22 smartphone, released in February 2022.
No cellular connection after replacing battery and charging port
I recently replaced the battery and charging port on my Samsung S22. Both seem to work fine, however I no longer get any cellular signal. I've double checked that all of the connectors are properly seated and reset the network settings without any luck. Any ideas?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
@oldturkey03
Turns out, the new charging board was damaged on arrival. I swapped the old one back in and the mobile data started working again. I guess I'll keep living with a finicky charger port until I can get a new part in.
(It's not a 5G phone btw)
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
@benjaminbashor Great. Glad you figured it out and got it working again.
из
Наиболее полезный ответ
@benjaminbashor double check your work. Remember that your main antenna on a plastic cover on the top. Make sure that everything has been put together again. You are not telling us if you have a 5G, those antennas are in a different place.
Оценка 1
Добавьте свой ответ
Benjamin Bashor будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 10
За последние 30 дней: 71
За всё время: 1,118
