Explore the Big Joe Task Support Vehicle J1, a versatile machinery designed for lifting and transporting items in various settings. This page offers detailed information and guidance for its maintenance and repair.
Why my Scotty speedometer not working
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Please check the meterconsole cable is connected well or broken. Its is cable that attached with front tyre and speedometer. If did you notice the cable is not working then replace with new meter cansole cable. ( Also check that your Km - reading meter is working or not. If the both meter are not responding then you just confirm that it was problem of the meter console cable. If only the speedometer was complaint then it was the only problem of meter console system)
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
My aerox not starting in morning.
из
Добавьте свой ответ
Dio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 838
