Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Replace DVD with SSD in iMac A1224 Early 2008
iMac A1224. Early 2008
I am trying to replace the DVD with an SSD
The enclosures on sale have the wrong connector to connect with the iMac lead in the machine
I think the SSD enclosure I bought has an SSD fitting on the front edge. I think I need an enclosure with a different type of fitting on the outside to connect with the internal lead. Could this be an ATA or a PATA (I'm not sure.
Has anyone had the same problem and overcome it please?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
mmm… I think you need to rethink this.
The optical drive connection is the older PATA interface which is why you can’t directly connect the 2.5” SSD into the optical drive port on the logic board. You also loose the performance the SSD could offer so I think you need to look at swapping out your current HDD.
But even that has its own issues! First off the version of SATA interface this system offered is SATA II (3.0 Gb/s) today most SSDs are SATA III (6.0 Gb/s) and as the demand for dual speed drives is mostly gone (you being the exception here) todays drives are not able to auto sense the lower I/O speed so they will drop data in spits and spurts when the buffers run out. So while it will appear to work the system will hobble along with issues.
So lucky there is a few dual speed drives still being sold Samsung 850 EVO spec sheet note the Interface clearly states the drive supports the older SATA spec’ed systems. So what ever drive you use needs to state it clearly, if not don’t use it.
OK, that’s only leaves the size difference between the current drive and the new SSD. You’ll need an adapter frame and that should do with the needed screws to mount it to the current mount points.
Last issue is the cobblers dilemma! You’ll need to setup a bootable external drive (FireWire or optical) if I remember correctly this system won’t boot from a USB drive. So hopefully you have your original CD/DVD’s or have a FireWire drive which you can setup as a bootable drive with the needed OS installer files. The highest Mac OS-X this system supported was OS-X El Capitan (10.11.6) if upgraded to at least 2 GB of RAM.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks. Very detailed response really helped.
из
@johnwalk - If you are set, don’t forget to accept the answer - Thanks!
из
Добавьте свой ответ
JohnWalk буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 266
