Device is lagging and keyboard button are not responding well
The PC is lagging and the keyboard button is not responding
Это хороший вопрос?
Это хороший вопрос?
Hey, @abhishekth61196
Take a look at your device diagnostics and see if you have a sufficient amount of RAM, or if your stick(s) are fully connected, as device lag when on offline function is often caused by a lack of RAM. Additionally, I would scrub the HDD. This can be done in two ways. The first is manually, which will take at least a half hour of clicking around. To do this, enter your File Browser (Assuming you're using windows and not a Linux variant) and just enter every single folder for every single little thing and remove stuff that's unnecessary. Unless you have extensive software knowledge, this can be risky because you may end up deleting vital programs that allow your apps and device to run optimally. The other method is CCleaner, which I've been using since the Windows 7 Release. Just download it from the website, and have it scan, then run, and repeat that 3x. It's worked miracles on old and new computers I've had brought into the shop. Good Luck.
Был ли этот ответ полезен?
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 141
I'll do my best to provide at least one solution for you, but some additional information would be helpful
из Russell Repair Co.
@indianarepairs yes as my laptop space button is not clicking we have to press it twice or thrice for it to be use and some other button too as shift plus volume+- buttons etc
из Abhishek Thakur
