Nintendo 2DS Touch Screen not working
Hello, my Nintendo 2DS Touchscreen is not working how do I fix it and what do I need (the bottom and top ONLY register touch)
Это хороший вопрос?
Это хороший вопрос?
You will likely need to buy a replacement screen and follow this procedure. The screen should come with the touch digitizer which seems to be the problematic component in your device.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 21
За всё время: 70
2 Комментариев
@maximusgabriel, can you clarify the problem you're seeing? I can't quite make out what it is you're trying to describe. You mention a touch screen issue, implying it's not the LCD but rather the digitizer that's the problem, but then you say the bottom and top ONLY (?) register touch. I don't understand what you mean by that, so if you could elaborate we'll be in a much better position to help you figure out what's wrong.
из Jerry Wheeler
@dadibrokeit
The bottom and the top of the Bottom screen only register touch
из Maximus Gabriel
