The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Black screen on display and external monitor
I have change the motherboard, battery works, it chimes at start but only gives black screen in the internal display and external monitor, is the motherboard faulty or is something else ?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
What did the original logic board show you? I would double check to see if that is also failing in the same way. Maybe you have a different problem.
Are you sure the external display connection is good? If that’s the case then it’s likely you have a bad logic board.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Mitigations буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 98
