Picture blinks on and off but the sound is fine
Picture keeps coming on and off but the sound is fine,is there a replacement board to fix the problem?
Это хороший вопрос?
Это хороший вопрос?
@waltthompson you are not giving us much to work with here. We do need to know what model your TV is. Returning a quick and dirty answer based on the information we have, this is not a board issue but a backlight issue. Your strips are turning off, cooling down and then coming back on. Replacing the backlight strips will resolve this. Sometimes you can determine if it is the strips by decreasing the brightness of the screen. If you set it to 50% or so and it stays on longer , you know it is the strips.
Now, this answer may change if more information becomes available.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 28
Hi @waltthompson,
What is the model number of the TV?
Can you view the TV menus OK without the screen blinking?
из jayeff
Flickering on an LG TV could be caused by various factors. It might be due to a loose cable connection, a malfunctioning power supply, or even a software issue. To diagnose the problem, I recommend checking the cable connections first and ensuring they are secure.
из Asha Kanta Sharma
